750cc RC Engineering HighImp (no resistor box required) Injectors (QTY 8) $350
maybe 1k miles on them ~72lb/hr
Inline Walbro 255lph High Pressure Fuel Pump w/ adapter fuel line kit $100
(no cutting into your existing lines on a fox) maybe 1k miles on it
Thanks for looking,
Scott
Mission, KS (I-35 and Lamar)
785.218.3741
Also....
HP Performance Stage 1 Turbo Kit - http://hpperformance.com/1979-95mustangturbosystems.htm
- Jet Hot coating has started to peel in a few places on the headers. Was quoted by JetHot between $250-400 to recoat them depending on which coating - Standard (current) coating or the 2000 degree (black) coating.
The kit Price reflects this...
- Turbo is in great condition - Less than 2k miles on the kit.
- Have an extra piece i had made to replace the MAF if using MAP. Still has the c&l maf that came with the kit as well.
- Extra wideband bungs already welded in.
- Upgraded Blowoff/bypass valve - metal and faster acting than the plastic one kits come with
- Does not include Fuel injectors or electric fan
$2000 - open to serious offers
Ford Crankcase Evac Pump and Moroso Catch Can Kit w/ Switch & Relay $70
Steeda Tri-Ax Shifter Handle - 79-93 - $10
Steeda Heavy Duty Rear Swaybar 1979 - 2004 - $80
http://steeda.com/products/hd_rear_sway_bar.php
Steeda Driveshaft Spacer - $25
http://steeda.com/products/steeda_driveshaft_spacer.php
AutoMeter Ultra-lite Mechanical Boost Gauge - no scratches - $30
70mm Polished Throttle Body - $120
- Believed to be older Accufab - not labeled
- includes polished spacer and new TPS sensor. IAC too if interested.
Thanks for looking,
Scott
785.218.3741
Also....
