1 - 17 of 17 Posts
Hi, I bought this 97 Cobra recently. It has a 6 speed trans in it. I am trying to figure out what 6 speed it is, to get specs to choose rear end gears/tire size. Anyhow, the interesting part is that reverse is all the way right and up. Most trans patterns for these put reverse left and up. The shifter body is also square where it bolts down to the trans housing. Any idea of brand/specs?
Any ideas of where too look or help would be great, thanks
Al...
If it looks like this, it's a 2003-2004 Cobra T56. It's a direct bolt up so it's the most likely candidate.
1058067
Awesome, thanks...
Any idea if the speedo sensor crosses over to the SN95 body, or not???
if the sensor is on the trans, is it 2 wire or 3 wire?
and your car's plug is 2 or 3 wire?
2 wire will be VRS and 3 wire will be hall effect
I was curious about the factory Cobra T56 ratios. So I looked them up they're 2.66/1.78/1.30/1.00/0.79/0.63
With those ratios I'd be all over 4.30 gears
You need to get the part number off of the trans. Not all T56's have the same gear ratios or speedo setups. I have an aftermarket T56 for Ford with mechanical speedo (Part number TUET 1259) and it runs a 2.97/2.07/1.43/1.00/.80/.62 ratios.
I'm gonna get under it in the next day or so and look for a data plate somewhere on it. There is a that says Mercon/Dex that I can see...It has a Dallas Mustang Speedo calibrator inline, wonder if that works or not. Think I might check the gear in the gauge too..
Oh, ya, btw, speedo doesn't work...
It has a Dallas mustangs speedo Cal box on it. that looks like a 2 wire setup, not sure if it works or not, can't get any info on how to test it. I have an actual Ford Electrical manual on its way, supposed to be here today.
Ok... so Saturday final came around. Got in there and looked like the speedo calibrator was wired correct. PO had power pulled from run hit in radio. Of course almost all of those wires are hacked. So I checked the fuse, and Viola, I have a speedometer. Thanks for the knowledge and ideas.
I would have have rewired it to it's own circuit or an unused circuit. But glad you got it sorted.
Discussion Starter #15
The fuse was blown because...
I removed one of the alarms installed by PO’s. I seem to remember hearing a pop when doing/moving some of the wiring. At that point o had been removing LED strip lighting and crawling around under the dash. While removing alarm(crappy, no remotes) we would remove one connection, try to start, and so on. I thought maybe one of the door lock wires was cut somewhere and didn’t check any fuses till I got the wiring book. Once I had that and started figuring out “everything” that was affected. I found the Lights,radio,mirrors,door lock fuse was blown.
I will wire it to a dedicated circuit as I repair the radio wiring in hopes of bringing it to at least stock.
Discussion Starter #17
Indy... I see your point, other than trying to start it each time between disconnecting modules, I should have been doing it cold to avoid fuse troubleshooting.
1 - 17 of 17 Posts
