I was going to get some of these for my 91 but I just heard that they might have stopped making them because they were going bad after a short term?? Does anyone have any input on this? If this is true then how are the 50's working out for most people?
I have done some searching and it looks like anything over 42#'s in high impedance is crap. I guess the thing to do would be some 72 or 83's in low impedance along with an injector driver. Does anyone know where to get a cheap injector driver for the stock EEC-IV? I also heard when you run a huge injector and MAF like this you lose some low end resolution on the meter and you also have to run a MAFturburner or some such thing. Does anyone have any real world experience with this stuff?
SEems like it would be cheaper to just buy a FAST or AEM...
Thanks,
Trent
50's work fine so far, but i have to install my 72's with low imp driver for PMS.
I also have a 80mm cal'd for 72's. Error in flow sheet is high at low flow but less than a lot of others i saw.
Ill post my results when all the work is done.
Alan Kennedy is one who really pushed SD into the 55s. AT one time he was the sole distributer of the 55s. He and I are good friends and I haven't heard of any trouble out of them. 55s are probably the limit on high impedance, but I haven't heard of any burning out.
Can you tell me were you heard this, I sell alot of these and have only had one complaint. On that one complaint, the injectors proved to be fine. They are going into Herman Stolzenberg's soon to be 9 Second 03 Cobra.
i run 50 lbs injectors. i believe they are made by delphi. i have had no problems with the injectorson my stock cammed s/c car. plenty of fuel delivery and good driveability.
