1 - 11 of 11 Posts
Well done video and damn impressive numbers. I like how it was all off the shelf stuff.
Sent from my SM-G965U using Tapatalk
Sometimes I hate videos. I like to just read the information. I can see what parts were used and the results and if I want more information I can read the article in detail. At first all I want to know is what HCI package did they use and what power did it make at what rpm. Maybe I don't want to invest the time to sit and watch a video or two. If I remember, I'll try to look at these when I have time to watch the video(s).
I liked when they took the 1 5/8 headers off for a pair of 1 3/4 to show the power increase. Helped make the decision easier.
Lunati Voodoo 241/249 duration 110 lsa 0.600/0.600 lift
4.303" bore
-6cc mahle pistons
10.4:1
AFR 205 Competition Heads, 58cc
Lunati 1.6 Roller Rockers
Victor Jr Intake
Quickfuel 750 Carb
Electric Water Pump
93 octane fuel
Hooker 1 5/8 Long Tubes
[email protected]/[email protected] 1st pull
466/440 2nd pull timing increase
495/441 3rd pull timing increase
504/446 4th pull timing increase
507/447 5th pull timing increase
Lunati Solid Roller Cam
246/255 duration
1.7I/1.6E Jesel Shaft Rockers
11.2:1
Super Victor
950 cfm Carb
Hooker 1 3/4 Long Tubes
527/452 headers/750
532/452 headers/950
541/456 headers/950/cam
556/455 headers/950/cam
566/455 headers/950/cam
Those AFR 205 renegade heads are really what makes that combo shine. My father has a stock block 347 in his 69 Mach 1, and it makes about 485 horsepower with a Lunati camshaft similar to the videos, same intake, 1 5/8 hooker headers, 750 carb, but it uses mildy worked over Victor Jr heads.
What I like about the AFR heads is that you can pretty much just bolt them on without doing anything to them. Also I would agree that 8000 rpm in a stock block is not very safe. You can put as much horsepower as you want in a stock block, and whatever rpm too... however the block is going to break eventually.
I know they were going for as much as possible but at 8k and all that extra money in the valve train/carb for 60 hp. I would be more than happy with the 500 and change at 6K rpm.
1 - 11 of 11 Posts
