Hey guys, first post on the forums!
I'll get right to it. I picked up a 5.8L windsor from a buddy for cheap and I am planning to drop it into a 1999 Mustang with a t5 5-speed this year. The motor it turns out was rebuilt back in 2009 by Jasper Engines and the only thing they changed in the upgrade is the camshaft. The motor was supposed to be going back into a truck for a business my friend worked for but they ended up scrapping the truck.
So I called Jasper Engines and they said all that was changed was the camshaft so a "High Performance" cam.
Now here's where my confusion is. I'm looking for a good street-able cam for this motor and everything I'm finding lists a lift somewhere in the .4-.5 range. The high performance cam they put in, they said its lift was around .28something. (Don't have my notebook in front of me at the moment. They say they didnt shave the heads at all. This cam is designed for hauling. The lobe separation angle is 110 Degrees. Not a good cam for a mustang as my mentor tells me.
My question is this; I need a high performance Street-able cam to put in this. but do I have the clearance to put in a cam with .4 something lift? What would you guys suggest for cams and Yes i am going flat tappet. First engine build im not going crazy expensive.
A side note, the motor WAS fuel injected but im swapping the manifold for a carbureted one. Less stuff to mess with. And yes i know emissions will be difficult to pass but ill take care of that. Thanks for any help in advance!
