Hey yall,
I know there are plenty of discussions on this swap already but basically here is the story. I bought an 02 GT from auction a few years ago for 500 bucks as as project car. Had a blown motor. I was still new to cars at the time so after searching, I saw a somewhat built 5.4 engine that was in an 01 GT. To make a long story short, the engine is now in my car, and is running, after some modifications for the last year. Im pretty much done with project, it runs well. However, I got it tuned recently, and I think the car is underperforming so I have a few questions when it comes to this. I was under the impression that you could get these things in the 300s or close to it to the wheel, obviously making more tq than hp, but maybe not. Here is everything the car has:
-2000 F150 2v 5.4
-Ford Racing shorty headers
-24lb ford racing injectors
-Comp stage three cams (have to verify this, this is what I was told, it sounds like it has bigger cams but not sure if stage 3)
-Trick Flow intake system with adapter plates
-75mm SR performance throtttle body and Cold air intake
-Flowmaster high flow cats and exhaust
-410 rear
-Stock heads and fuel system
Car made after tuning 250/300 whp and wtq. The tuner told me thats all that car is going to make. I know these aren't huge power monsters, but I figured I could break 300, and to be honest 250 on that thing is a little lack luster.
So here are my questions... do you think that it should be making more? What should I do (minus forced induction) The car maxes out at 5200 rpms. I know the HPS hardballr intake is probably better since it gets more air and doesnt change the position of the injectors, but do you think it would make a big difference?
If I did go forced induction, is there anyway of getting the lightning supercharger (eaton m112 i think) under the hood without cutting it? I know a procharger would fit but Id rather go whipple for cost reasons. I have the stock hood right now and it clears, but probably upgrading to a cowl hood in the near future.
Thanks for the advice/help.
-2000 F150 2v 5.4
-410 rear
