What are your intentions with the car? Plethora of bolt ons that work with the factory computer AND injectors. Heads, cam, intake, long tubes yield around 300hp to the wheels without changing a thing electronically.
It's definitely going to need some kind of an ECU as it's a four-banger right now. The intentions just a fun weekend warrior it's quick enough to get out of its own way. I'm not looking for 700 horsepower or anything like that. I was thinking a slightly more aggressive cam with maybe a stroker kit. Maybe some heads in an intake in the future.What are your intentions with the car? Plethora of bolt ons that work with the factory computer AND injectors. Heads, cam, intake, long tubes yield around 300hp to the wheels without changing a thing electronically.
In that case go carb. Then you can do whatever you want and don't have to negotiate with Microsoft every time you step on the gas............ Get a Progression Ignition distributor for it. It will build a base timing table for you that you can play with for fine tuning, nitrous etc... It Bluetooths to your phone.It's definitely going to need some kind of an ECU as it's a four-banger right now. The intentions just a fun weekend warrior it's quick enough to get out of its own way. I'm not looking for 700 horsepower or anything like that. I was thinking a slightly more aggressive cam with maybe a stroker kit. Maybe some heads in an intake in the future.
Meant to say self learning.There is no such thing as self tuning.
Right now it's got the stock 5.0 EFI intake. I'm just trying to figure out what I should use before I start ordering parts. I'll look into both of those.Cheap and decent EFI, A9L computer with Moates or Tweecer. (Only cheap if you already have the harness and ECU)
Since you're familiar with the sniper if you already have a carb intake it would be a good choice.
Or upgrade to a Terminator X if you have a multi port intake already.
Didn't Moates close??Cheap and decent EFI, A9L computer with Moates or Tweecer. (Only cheap if you already have the harness and ECU)
Yes.Didn't Moates close??
