Well I installed the ARP head studs and the gaskets are in place, I finished the SH stud girdle and windage tray, it all fits like a glove, I will set the heads on tomorrow, I will take pictures so that those of you that have never seen a 4 V go together it is easy as long as you take the time and use the right tools. after that I will show how to set the cams up with the D slot positioning tool then the Crank/cam chains go on, again its easy with the right tools. With Fox Lake ported heads this will be really nice setup. The one picture shows actual piston weight, he ballances every thing does real good work.
