I have a 414" sbf for sale complete from carb to oil pan...and either a flexplate for you auto guys or flywheel for you stick guys! Fresh motor...has "0" miles on it....was only started in the driveway for about 30-45 min to break-in. Shortblock was built by Gunther's Machining & Rebuilding using a 1970 early model 351w block. Motor is a 10.5:1 compression pump gas motor!! Has eagle crank and rods with arp rod and main bolts. DSS SX series forged dish pistons. King main, rod and cam bearings. Sealed power moly piston rings. Melling high volume oil pump. Professional Products SFI harmonic balancer. Heads are Pro Topline 200cc heads with a 5-angle competition valve job, new seals, upgraded k-motion dual valve springs and flat milled before assembly. SVO 1.6 roller rockers. Trickflow chromoly pushrods. Morel link bar hydraulic roller lifters. Big custom grind CompCams hydraulic roller cam(specs to buyer). Victor Jr intake. Holley 950hp carb with dual 50cc accelerator pumps, jet extensions, 130 needle&seats and dual feed line w/ liquid filled fuel pressure gauge. MSD billet distributor. Edelbrock victor series high flow water pump. Underdrive crank pulley. Tall aluminum valve covers. Solid motor mounts. Also has a 351w swap dual sump pan on it. All you have to do is drop it in your car and add your own exhaust and you're off running. Easily a low 10 sec pump gas motor...then add a small shot of nitrous and head straight for the 9's!! Asking $5500 for this complete engine!! Call/text me direct @3013953921
