1 - 8 of 8 Posts
So I recently got my car back together and running. I rebuilt it because it didn't run right and after a compression check found out the rings were worn out. So fast forward I decided to do a on3 turbo kit and switch out cams and valve springs. Now compression check comes back at 150 per cylinder and leak down is around 20%. I am at a loss, the car is running a super sniper and runs ok, besides over heating now after driving awhile. Looking at my combo can anyone see anything that would cause a low vacuum at idle? I've also checked for vacuum leaks numerous times just to be sure and have found nothing. I'm just at a loss of where to go from here or what to check.
Cam - .634/.601 @50 258/278 114 lobe seperation
Valve Springs - 987 Comp Cams, Harland Sharp 1.7 RR and Trick Flow 7.7 pushrods
Vic Jr Heads & Intake
Holley Super Sniper 1250
on3 turbo kit
what is manifold pressure and idle speed?
  • Like
Reactions: Cougar5.O
Manifold pressure is about 1-2" at a 1150 idle speed. If i got to around 1,800 i can get around 5 but i wouldn't think that cam would need to idle at 1,800 RPM to gain any sort of vacuum. Timing is at 23 degrees but I've tried anything from 11-28 degrees with no change.
so
intake valves open
air is getting past throttle blade
exhaust is plugged
you say leak down is 20%? that is not good
try a smoke test....
what is the cam expected to make, manifold pressure wise?
Discussion Starter · #5 ·
so
intake valves open
exhaust is plugged
Indy, i had a similar size cam to this before and made 16" so I'd say maybe 10-12". I will try the smoke test next. I didn't think of that, I was wondering if the springs were maybe keeping the valves open slightly.
Did you degree cam? Cam timing off or ignition timing.
Also, make sure the valves aren't adjusted too tight.
  • Like
Reactions: stangjumper
perform a relative compression test by sound
crank without it starting, listen for consistent crank, without a speed up
1 - 8 of 8 Posts
