Thats what my set-up is in my 92. Anyone have a similar set-up? Is that too much gear to run the quarter without going into overdrive?
PM Jeff Chambers he runs AOD race car and has lots of info. He's either on corral or Mustangworks
depends on what rpm the motor falls off at and if your going to run 26 or 28" tires. you should dyno the car to find out were you fall off at.
I'm running 4.88's with the lock-up AOD and have never used O/D; good thing that I haven't needed to since it has been removed from the trans! Anyways, with the 4.88's and a 26-inch tire I'm passing through the traps at a little more than 8100 rpm at 130+ mph. That's with the trans in third and converter locked up.
i guess i could show my rpms & speed "stock motor car"
4.10's + 26" tires = 5500rpm's
Hey Scott It looks like youre right on the money
Bill
