My car came wired with a 3g alternator. It works fine, but is this the correct wiring? (I did not do this, just making sure it's correct) The D plug has two wires coming into it, a yellow with white stripe and a green with red stripe. The white with (I think) black stripe comes out of the D plug and goes to the small white connector. So, there are only two wires coming into the D and one going out. The stud had only the large red cable which is fused and goes to the starter terminal. The black orange wires are not used.Is this correct? See pictures for reference.
Thanks. I just am paranoid about electrical fire.
Chris
Discussion Starter #2
I found my answer. It is correct.
That sure is hacked up. I would not run anything like that.
It's all rewired with new plugs now.
