1 - 10 of 10 Posts
Hey guys building a 377w svo 9.5 block bought a shortblock dont know much about it has build sheet but not alot written on it has eagle rods and a ford racing crank. Has venolia inverted dome pistons. Was wondering what size combustion chamber would be the best for boosted application. Want to go with the AFR 205 heads dont know whether the 58cc or 72cc
Discussion Starter #2
Want to have around 9:1,10;1 compression gunna be a street car hyd roller motor going to be on 91 pump gas
I've used this calculator in the past for static. Just need to input the info. Calculator located at the top of the page. Hope this helps
Vendor
Flat piece of plexi with a tiny hole. 2 dollar graduated burret and do as the picture shows except with the piston. Problem is if the piston is below the deck at tdc it wont work since the plexi needs to lie flat on the piston.
1 - 10 of 10 Posts
