Fresh machined and assembled 351 Windsor. 1969 block and crank, Scat I-beam rods, DSS forged flat top pistons, balanced rotating assembly, SFI balancer, cast iron 157 tooth flywheel, ARP fasteners, Trick Flow hydraulic roller cam, Crane link bar roller lifters, Trick Flow Twisted Wedge heads, Crane Gold roller rockers, Weiand Stealth intake, standard rotation water pump, Fox body 5 quart oil pan, Ford Racing tall aluminum valve covers. Assembled, painted, detailed and hot tested. Currently still sitting on hot test so serious buyer can hear it run. Distributor, carb and headers not included. Possible barter.
