I'm not one to criticize another man's build but, you'll have one hell of a time getting a few sheets of plywood home in that thing....
If you have the right tools its not that hard, but there's a lot that can go wrong regarding bearing bore alignment. Sometimes the bores aren't straight (even from the factory) and the bearings will need trimming to get the bores to line up enough so the cam will turn freely. Most of the common cam bearing tools for a SBF don't work well, mainly due to the staggered cam journal sizes.Why does everyone avoid changing cam bearings? I've watched a friend change cam bearings a couple times.
Need a small base circle cam because the non roller block has a shorter lifter bore. If you use a std base circle cam you run the risk of the oil hole on the lifter body becoming exposed at max lift, then the lifter has no oil pressure. Some of these non roller blocks have an even shorter lifter bore because ford loved to put a huge radius on top of the lifter bore, which makes the bore even shorterI’ve got a roller 5.0 sitting on the floor and it FITB me thinking, can I put the cam and roller lifters/spider in the 88 Windsor at came with a flat tapper cam? I’d drill and tap holes for the spider obviously, just wondering if I would need an undersized journal type cam or would the lifters pop out of the block etc
I found myself in a very similar situation.Well…. I got some 460 parts and was leaning that way… I also have a roller 5.0 block that would take the gt40P’s and there is a 302 in it. The 351 is still on the engine stand, covered with fender covers….still thinking…
Once the car is on the track this summer with the 302 in it and I work out any bugs from sitting 25 years, I think I will build the 351 but now it’s looking like it’s not going to be a “rering and bearing” like I was hoping. I’ve got some forged 302 pistons out of another engine and with the 351 rods…a 3.85 stroke crank would definitely get me the 3-350hp I need…
All that to say… still contemplating 😂😂😂
I do want to run a 460 at some point but perhaps not in the white mustang.(oh yeah, since this started I picked up a 86 mustang lx with a 3.8 for the wife)
351 forum but here is some videos of my blue 86 that was supposed to be “all plated and legal, drove it the other day”…🤬🤬🤬
and then more problems…
And then more…
3.8😂😂😂 NOT a powerhouse😂😂
