Sitting in the garage and needs to go...
Moroso Street/Strip Oil Pans 20520
Wet Sump, Rear Sump, 7 Quart Capacity, 9" Deep
Fits: 1979-up Mustang, 1981-'88 Thunderbird & Cougar,1979-'86 Capri and other Ford rear sump applications. Now with billet end seals for greater sealing! Oil Pan, Steel, Fully Fabricated, Clear Zinc, Deep Sump.
Engine Application: 351W
Fits: 1979-up Mustang, 1981-'88 Thunderbird & Cougar, 1979-'86 Capri and other Ford rear sump applications. Now with billet end seals for greater sealing!
■Steel with a clear zinc finish
■9" deep rear sump
■Clears all 4-bolt main caps including 4-bolt rear
■Accepts 4.0" stroke with most steel rods
■Oil sump retaining system
■Compatible with most starter/flywheel combinations
Moroso Oil Pump Pickups 24532 included
$200.00 + the ride...
214.206.6384
Jeff
■9" deep rear sump
214.206.6384
Jeff
