Ok heres my combo on motor
351w with 9:5:1 compression
nitros cam duration at .050 is 232 int/ 244 exh
gross valvelift is 565 int/ 580 exh
lobe seperation is 114 degrees
rpm range is 2600-6600
Trick Flow Twisted Wedge Heads ported/polished
with the cam lift heads flow 284 cfm int/ 173 cfm exh
trick flow R intake with rpm 1500-6500
70 mm throttlebodie 30Ib inj 75mm mas msd 6al msd coil
stock computer
Any suggestion on a better cam selection I would like to have about 600 lift. Also dont know what size rockers to go with.
stock computer
