1 - 13 of 13 Posts
can i get a little input as to what cam may perform best with my combo? here it goes: 94 gt,4r70w,2500 stall ,373 gears
357 windsor with flat tops,trickflow 170s,single plane intake,750 annular carb. heres the cams im considering
olid Roller Cam. Good cam for high performance street or mild strip applications, in 302-351 c.i. motors. Needs 2500-3000 RPM stall converter or 4/5-speed transmis- sion, headers, 9.5:1+ compression ratio and 3.73+ gearing. Rough idle. ; Advertised Duration (Int/Exh): 267/273 ; Duration @ .050 (Int/Exh): 237/243 ; Gross Valve Lift (Int/Exh): .602/.616 ; LSA/ICL: 110/106 ; Valve Lash (Int/Exh): .016/.016 ; RPM Range: 2500-6800
Hydraulic Roller Cam. High performance street/bracket cam. Needs 10:1 compression minimum, increased induction and exhaust. Needs 3.55+ gearing. Requires computer mods. Very strong above 3500 RPM.; Advertised Duration (Int/Exh): 282/290; Duration @ .050 (Int/Exh): 231/239; Gross Valve Lift (Int/Exh): .571/.587; LSA/ICL: 110/106; Valve Lash (Int/Exh): Hyd/Hyd; RPM Range: 2600-6600
or comp cams xr280r any helpi will appreciate
With the 2500 stall and assuming a full interior 94 which is a little portly compared to the older Foxes, Id run something like this: Should be a nice broad power band.
Xtreme Energy XE274HR
Comp Cam Data Sheet
Part Number:35-518-8Grind Number:XE274HR
Lifter Type:Hydraulic Roller LifterEngine Type:FORD 5.0 (1982-2001)
RPM Range:2200 to 6200Valve Timing :0.006
Lobe-Center Angle112Intake Center Line:108
IntakeExhaust
Valve Lash:Hyd.Hyd.
Duration:274282
Duration @ .050" Lift:224232
Valve Lift:0.5550.565
Lobe Lift:0.3480.354
Valve Timing @ 0.006" Lift:OpenClose
Intake:29 BTDC65 ABDC
Exhaust:77 BBDC25 ATDC
This idea that the weight difference between Foxbodies and SN95 cars matters should just die already. The difference is maybe 200 pounds when comparing similar configurations. That's a passenger. Maybe a passenger and some stuff in the trunk. But it's not insurmountable and a 357W is not going to notice it.
Agreed, but my point was more about being a full interior street car versus maybe a gutted out race car. Should have been more clear.
thanks guys for the responses,car is mostly gutted,it is a "89 351 block,will be using link bar-lifters,im personally leaning towards the lunati solid roller cam but i wanted some opnions of some of you guys that know more than me
its a street and strip car,i dont mind making adjustments on valves,done it before on another solid flat tappet i had...
I have a 352, tw205, sv intake, 9:1, 238/242 619/629 solid roller. Made 480hp at 6700 with a very flat rpm power band. Ran with 650 carb and 1 5/8 headers. Bigger carb and intake it would make 500hp+. Nice idle and great drivability. The constant lash adjustment shouldn't happen.
Cam is for sale if your interested. Going a different route yet again.
thats great,i like your combo,only diference i see is your heads are bigger ,can tw 170s be spun to 6700 rpms?
If the cam and valve train are up to it, 6700 is nothing.
Have a friend with a 327 or 331 with a large single turbo that dynoed 1200-1300 hp that had the power still climbing at 8000rpms with out of the box tw 170s. We were all shocked.
1 - 13 of 13 Posts
