347 stroker w/ stock block
Scat forged crank from machine shop still in bag
Forged Ross XL400 pistons (accepts TW heads too)
Not sure who makes the rods
Main studs w/ main girdle
Main caps were grinded for more surface for the girdle to contact
Cam bearings were changed
Crank was cut I believe 10/10
Has new Clevite 77 H series bearings for the new cut but might need to look for them
Currently disassembled
Has been sitting in a garage so cylinders might be a little rusty so will need a quick hone to clean up the walls
Good clean/clearance check/assembly and should be good to go
I was going to use this but had to sell the car so no longer need this.
First $1100 takes it
Any used parts have very low miles
Located in Toms river, NJ
I have more pics but they're not working for some reason
