EDIT: Car is for street and will be driven regularly, it may see the drag strip once or twice over the summer but is not being built for the strip
I know every little thing related to 347s has been beaten to death on these forums already...but ive got more!
Im looking to start building my 347, picked up a complete 302 last week and will strip it down next weekend and send it on its way to the shop.
Now im looking at two places, CHP and ADperformance, i have heard great things about both companies.
(also to get this out of the way, im not going to be buying a pre-assembled short block block because i would like to build my own engine--yes aware it doesnt make sense when woody and people like him have a million times more experience and knowledge but im looking to learn something)
I will be using a stock 302 roller block, and it will be going into a street car. To start off i just want to build a solid 347 that i will progressively upgrade in the H/C/I departments. After all mods are done im not expecting anything over ~425hp.
I would appreciate some input on making an informed decision between the kit that CHP offers and the kit that is offered by ADperformance. Each kit is with FLAT TOP Pistons.
CHP: The Street Fighter Engine Kits are engineered for high performance street and limited race applications. Cast Steel crankshafts, forged connecting rods and lightweight Probe SRS forged pistons are the norm. The Street Fighter is comfortable when used with power adders, and 500+ horsepower is common.
Street Fighter Inlcude:
* Probe SRS Forged Pistons
* Probe Cast Steel Crankshaft
* Probe Machined Beam Forged Rods
* Moly Rings
* CL77 Bearings
THIS ALSO INCLUDES A FREE 28oz balance(Big benefit to me as the shop i go to charge 275 minimum)
price is $959.99 plus $40 shipped to my door
ADperforamce: Scat Street/Strip Rotating Assembly!
Scat Series 9000 Crankshaft, 3.40" Stroke
Scat 4340 5.400 I-beam Connecting Rods, w/ ARP hardware ***5.325" Rods available as an option ($75 charge) This makes a "short rod" 347***
KB Forged or Probe Forged Flat Top Pistons, Inline valve relief, Floating pin w/ spirlox, wrist pins
Clevite Rod and Main Bearings
File Fit Moly Ring (Manufactures Choice - Perfect Circle, Total Seal, Mahle)
This kit will support 600hp from your small block Ford!
This kit does not include the balancing, it is $899.99 and for an additional $85 i can upgrade the rod bolts(little confused here because the ad sounds like the already have ARP hardware???) and the shipping is approximately $90 to my door.
I dont want to be cutting corners on parts that will cost me in the long run, but i dont need big horsepower parts, if i can save a hundred bucks on something that is unnecessary and get something adequate then im just as happy you know?
I've tried to supply as much info as possible and is needed for people to give input, thanks for taking the time to look and help out.
-charlie
* Moly Rings
* CL77 Bearings
-charlie
