Been doing some trials with water/meth injection on my engine. It’s 10.9:1ish compression running pump gas with a f1r. Video is at around 10lbs peak. Was good for 127mph with 3350-3400lbs total in the car, with an absolutely terrible 60ft. Timing is very conservative, and it’s being sprayed with a 1000ml nozzle at 100% duty cycle after about 7lbs. Engine specs are listed in my signature. Controlled with a ms3x (pimpxs)
Hopefully I’ll have a dyno video in the coming week or so. Going to pulley it down to bring boost up to around 14lbs at around 7000rpm. It’s probably the only procharger in the area running a cog for 10lbs of boost lol.
