I need some input on your combos. What numbers are you getting with your combinations. Mine will be EFI probably a street roller set up with 10.2cr and I can't decide on a intake. I am leaning towards the Victor 5.0.I will be using TFS street heat heads with a mild port job(looking for around 300intake flow).
Thanks,
Mike
Have a guy I that I ported a set of Tw heads, and a lower Cobra intake. He is running a hyd. roller cam, 3.73's, tremec, and stock upper, and he ran a [email protected] mph in 1/8th mile. His 60ft was 1.61, and had clutch problems. I like the Edelbrock intakes, since I can fully port them without having to cut/weld them. The Vic 5.0 should be a good choice if you are going to turn it around 7,000+.
Hope this helps you out some.
Good Luck, Greg(XSR)
