so I was talking with a gentleman has a fast car and has had a few cars and had some in Fast fords in the 90s anyways told him im doing a Swap Dss 347 to a Dart block he said no dont do it.
Here is the play brother.....build a big bore block to aid the cylinder head flow by unshrouding the valves.....
4.125" bore instead of the common 4.030"
That INSTANTLY makes more power by increasing head flow dramatically
Plus with a 3.25" stroke crankshaft instead of the common 347" 3.400" stroke you can have a longer lived engine because the oil ring is supported by the oil ring land instead of a spacer that is unsupported because it spans the area where the piston pin sits.
That makes ring seal go away, most street 347's are oil eaters and don't live for long. My big bore 331" setup is actually 348".....lol
Thoughts on this?
Thoughts on this?
