1 - 20 of 21 Posts
A couple of days ago, I started to hear a noise from the engine bay.
I've tried to pinpoint the noise with a stethoscope. It sounds like it's coming from the passenger side valve cover. I plan to start tearing into it tomorrow morning.
I took a quick video, perhaps someone has run into this type of noise.
Any assistance would be greatly appreciated.
That's the exact noise my alt was making right before it seized up.. Like the guy before me said. Remove belt and see if the sound goes away
I'd bet on idler pulley or one of the accessories. Only say that because had a similar noise on my F150HD, only lasted a few days before I heard a "clunk, ting ting ting", and got home to discover I was short a blower belt idler pulley.
Thought I would bump this up....really haven't been able to dive into it and looking for more suggestions/guidance/assistance before I rip it apart.
I did take the belt off and the chirping noise continued.
I removed the driver's side valve cover and readjusted the #7 and #8 rockers and pushrod guideplates but to no avail.
Thoughts/suggestions??
I will definitely look into this....
In addition, when I cold start, it does not make the chirping noise. It only starts the noise when the engine is getting up to temperature.
distributor bearing is failing.
Take the distributor out and run it. See if the sound goes away. :sneaky:
I remember when my alternator went out. Made a whole lot worse of a sound than that lol.
OH GOD NO!
NOT "CLUNK, TING TING TING" ....anything but "CLUNK, TING TING TING"!......:D:D:D
Discussion Starter #16
Ok, quick update....
Changed out the dizzy, to no avail.
Started taking apart the top half. Visually inspected lifters and saw no obvious issues. Still looking at replacing them.
What I did notice was on my SM2 lower intake, the pcv baffle shield was really loose. Don't know (or can't remember) if this how it should be. Looking for feedback.
Did this ever get resolved?
My guess is either it did, or he shot the motor.
I was just gonna ask if it was automatic. I had a similar sound once when an aluminum block plate was slightly warped and a tq converter bolt was hitting it.
The other one believe it or not, the PCV valve can sometimes make some ungodly noises especially with a Holly.
well, I hope he didn’t smoke check it.
Discussion Starter #20
I did get it resolved...
I ended up taking the heads off. What was obvious was the valves (mainly the intake side) on #8 cylinder was caked heavily with carbon.
All the valves were removed and cleaned, along with the heads. I lapped the valves to ensure I got rid of the pitting.
In addition, I went ahead and replaced the lifters as well.
Put it back all together and fired it up.
Issue resolved.
1 - 20 of 21 Posts
