Yes, ARP offers a bolt and washer, FTI carries them too.
Hello all. Having some trouble with the cam sprocket washer. I have the OEM washer, which is quite thick, but used a 3/8" bolt. I can't seem to drill this washer out to the 7/16 size needed for the comp cams camshaft. What has everyone done? Is there an ARP washer out there that replaces this?
Thanks a lot
Thanks. This comes with the washer too?![]()
ARP Camshaft Bolt - SB Ford - Billet Core
Custom Camshafts, Valvetrain, Valve Springs, Push Rods, Timing Setswww.flowtechinduction.com
Yes sir.Thanks. This comes with the washer too?
Thanks. Trying to order, won't let me enter a credit card number.Yes sir.
Supposed to be. I have ordered from parts stores where wrong gear was on.Thanks. But a distributor for an 85 should be steel geared right??
