I'm getting ready to come together with my 331 stroker and need some help on a cam for good 90% Street Driving and 10% 1/4 Drag Racing.
Specs on 331:
Stock XXX Block bored 30 over
Eagle 331 Rotating Assembly
I Beam Rods
Victor 5.0
Afr 185cc's (58cc)
Flat Top with 2 Valve Relief- Forged
Looking for 10.5-11.1 Range
93 Octane
Aod with 3500 Stall
30lb Injectors
73mm MAF
70mm Throttle Body
For the Cam I'm leaning towards XFI 236 the smaller version but I've been reading up on them that it's has a slight vacuum problem and that will be a problem for me in the street daily driving. So where I trying to get here is should i get a custom cam or just go with the xfi???
Specs on 331:
I Beam Rods
Victor 5.0
Afr 185cc's (58cc)
93 Octane
Aod with 3500 Stall
30lb Injectors
73mm MAF
70mm Throttle Body
