So I'm doing my first fox build and I was wanting to put a on3 turbo kit on it, but tunes are pretty pricey here so I was going to run a bbk fmu on it. Any recommendations? The setup on the car is trick flow 36# injectors, gt40p heads, b303 cam, 987-16 Comp springs, upper and lower typhoon intake, 70mm throttle body (no egr), with a ford maf sensor. I am running a stock computer and only wanting to run low boost as of right now 5-10#.
