1 - 9 of 9 Posts
Just curious but why would you want to swap to a 4.6?
I need a new motor and i found somebody that has a 4.6 and automatic trans out of a 98 mustang with 30,000.They want $700 for motor and trans .I think this is a good deal.The man went to a 600hp motor.Thanks Patrick
The 4.6 from 1996-1998 carry the old design heads. Stock they are so slow. Thrust me you don't want to go this route. I think like DarkMesa8 ,d'ont go to a 4.6 unless you use a dohc motor. I am pretty sure that you can find a good 5.0L motor for the same price.
Consider why the motor/trans is so cheap, than consider the cost at fixing a Modular motor. If the motor and trans were good, they would not have a pricetag for that cheap.
You can fix a Windsor easier than you can fix a modular. Even if you have a shop do it, they'd probably charge less to fix a Windsor than a Modular motor.
1 - 9 of 9 Posts
