I have had this for many years and never used it.
This bracket was modified by Alternative Auto to mount your fox 302 vortech kit on a 351. Without modification, the blower will sit higher and you won't be able to use the bolt that goes into the block.
If you research the corral, you will see this is supposed to make a vortech install on a 351 a snap.
