1 - 10 of 10 Posts
39
Discussion Starter · #6 ·
thanks guys. Mine is set at 36psi. I was just checking to see around how low I can go and still be safe. I think I will stop were its at.
My old 302 made 305rwhp and we had the pressure set at 48 psi.. my mass air meter was on the lean side.
Discussion Starter · #8 ·
What are the problems you normally have when you are lean?
Could it possibly cause your power to level off in the upper rpms?
you want to run as lean as possible w/o damaging your engine (detonation). i believe this gives you the max HP. Personally, I'd rather error on the side of being rich. You may lose a few horses and burn a little more gas, but you're less likely to blow a HG or damage a cylinder.
Discussion Starter · #10 ·
so if it was to lean it would detonate for sure??
I pulled a couple plugs and they are white like the day I put them in, but I get no detonation.
1 - 10 of 10 Posts
