Mine was an 09 as said already. I think up to 2014 the track assembly is mostly the same, indicating that the seat frame itself is similar. Remove all of the original track assembly and then bolt them directly to the fox body seat tracks. You will have to use some spacers and you'll have to drill the holes in the seat frame to mount the fox body tracks to them. They sit lower than fox body seats do even with some spacers, which I personally like since I'm almost 6'8". The only problem I have with them is that getting into and out of the car is now a little harder to do.
