Finally ordered all the supercharger parts for my daily driver Sonic Blue Convertible GT (really like my car!). I've Been waiting 9 years to do this. Already installed a T56 with Pro 5.0 shifter and electronic reverse lockout two year previous after two T3650 failures on a stock engine with mild daily driving. What a BIG improvement in shifting and gear ratios.
Background: 10 years previous built my original owner 88 GT to 450 HP with a Powerdyne SC, AFR heads, Stage II Roller Blower Cam, Roller Rockers, Speed Pro Pistons with matched filed rings, Stage II rods, Crank Girdle, Bassani 2.5 dual H Pipe exhaust system, with fully modded suspension, etc. Six months after finishing some a..hole ran me into a guardrail. Still have the car. Mechanically perfect, still starts but not drivable. When finished not super daily drivable.
So I am NOT going break my daily driver, keep OEM driving qualities and keep the tune safe. Everything I've read is do not exceed 400 RWHP. Is that correct or is it 400 HP off the motor?
Right now changing the clutch. Replacing the main seal is apparently a career event. Next replacing original 135K mi struts and shocks with KYB Excel-g units. Supercharger due in next week.
Victor
Parts list I settled on:
Vortech Supercharger Kit 4FL218-150L (V3) >> $3,130.00 - Aderson PKVT-GT04 w/ Power Pipe!
Anderson Power Pipe AF-0110A >> N/C - Anderson
K&N RU-2590 4" Filter >> $46.96 - Amazon (Replaced 3.75" Vortech when MAF changed out to blow thru)
BBK 78MM Throttle Intake 1780 >> $269.00 - Anderson
Ford 38# Injectors DEH-38-DH >> $349.0 - Anderson
Areomotive Stealth 325 Fuel Pump 111645 (replaced Maxed out DeatschWerks Fuel Pump 9-651-1015) >> $144.77 Ebay
SCT X4 Tuner 7015 >> $319.00 - Amazon
Exedy Mach 400 Stage Two Clutch 7805 >> $248.44 - Amazon
Steeda Clutch Quadrant Kit >> $112.03 - Aamzon
FelPro Teflon Rear Main Seal >> $21.00 - Autozone
Oil Slinger (Baffel) >> $14.00 - Capital Ford
Resurface Flywheel >> $32.00 - Carquest German Town
Center Force Throwout Bearing >> $44.00 - Piedmont Custom Motorsports
Ford Racing Pilot Bearing M-7600-B >> $11.00 - Piedmont Custom Motorsports
Pro-M Drop-in MAF/Flange (replaced SCT BA-2600 Big Air 90MM MAF) >> $242.97 - Pro-M Racing
NKG Copper Spark Plugs TR6 4177 >> $15.00 - Piedmont Custom Motorsports
Welding for Drop-in MAF, move BOV & re-weld BOV>> $300 - Piedmont Custom Motorsports
CXRacing Intercooler kit with 4" core upgrade >> $559 - CXRacing direct
TiAL QRJ BOV w/ 38mm Intlet and Outlet & 1.5 psi Sping (replaced Bosh BOV, CXRacing BOV, Vortech Maxflow BOV) >> $287.36 - Exstreme PSI
Vortech 3.48 Pulley >> $81.99 - Summit Racing
Dyno Tune >> $375.00 - Piedmont Custom Motorsports
Dyno Tune #2 >> $150 - Piedmont Custom Motorsports
Bassani X-Pipe with High Flow CATS $ O2 extenders >> $551 - American Muscle
Total >> $6,752.49
Victor
Total >> $6,752.49
