Back story, 2012, my wife's 01 Cobra with a 03 drivetrain swap unfortunately was wrecked when it met a freeway barrier. (She was fine, car wasn't.) After buying back our 01 I took all the speed parts off it and parted it out. We ended up fairly ahead with the buy back/part out and picked up this car. We waited for a bit and I had planned to go out of state for exactly what we want. We got lucky and this was listed locally. Our goal was to build it up to be an excellent cruiser for road trips but still be able to run down the track and hold it's own. I've used it in a dozen or so multi state road trips with friends. Wife doesn't drive it much anymore except maybe to work a few times a year. So it's pretty much mine now. It's the garage queen. We purchased with 41k, now has 67k. I spend more time on this one detailing it and keeping it as perfect as I can for a driver. I've mentioned it's the unsung hero. When my fox is broke or I just want to drive something without feeling too racecar, this is what I take.
From Utah, I've taken it to Vegas close to a dozen times. Grand Tetons twice, Route 12 in Southern Utah a few times.
Best 1/4 mile times for it at our track elevation was 12.72 @ 116mph on the street tires with wife behind the wheel. Best I ever did was 12.84 @ 114mph
It's been dynoed at 497rwhp/491tq.
Specs:
2003 SVT Cobra, Sonic Blue.
Posi Ported Eaton with 2.76 upper/stock lower. Makes around 11 psi at our elevation.
JLT intake, Posi ported plenum and TB. (Have an Accufab but took it off because it was sticking.)
52lb GT500 injectors, Boost-a-pump, SCT 2600 MAF
SCT Pro Racer Pack, dyno tuned.
BBK Offroad X-pipe, Magnaflow catback, Bassani resonated tips.
Upgraded dual pass universal heat exchanger.
Steeda Tri-ax shifter.
Ford Racing 3.73 gears, Billetflow IRS brace, Full Tilt Boogie differential bushings.
18x9 Front 24mm 275/35/18 18x10 Rear 22mm 295/35/18, Continental Sport Contacts.
Steeda Sport Progressive springs, Maximum Motorsports CC plates, sway bar end links, and sway bar bushings.
Cosmetic: 99-01 Amber tail lights from our former car, 3M satin black roof.
The stereo is one of my fav things about the car. It's just right.
Everything Mach 460 removed and trashed.
Pioneer AVH-X2800BS.
Infinity Reference Components front and Reference 2 way rears.
10" Kicker comp VR.
Alpine MRX-V60 5 channel amp. Mounted to a custom rack that goes where the Mach box was so it's totally hidden.
This picture was at the last event we did at the track before it closed.
Here's one of the many of us racing. She cuts a great light, usually .0xx. If I sleep even the slightest bit she'd get me.
Specs:
10" Kicker comp VR.
