Time to move on from this car...
This is the silver cobra from KOC last year and this year at Back Of Track race at TVRP in Noble, OK
03 Cobra
- 61k
-Stock Motor
-3.4 whipple (3.5 upper stock lower)
-BUILT 4R70W, Manual VB,T-brake, electronic OD and Lockup. FB Performance Valve body, Raybestos Stage 2 blue clutches, B&M deep pan)
-8.8 SRA 31 spline mosers,Auburn Pro Series Dif
-PA K member and A arms
-Strange Shocks and Struts
-Fore Tripple Pump Return system(-10 from tank to Y block, -8 everything else)
-SCT Xcal3(Car was tuned by my brother and my self
-Comes sitting on the 18" Saleen wheels (real ones) with 275/35 BFG KDW upfront and 305/35 MT Drag radials in back
Car is 100% safe on current tune. IF you want to crank the boost up you will need to ditch the 80's and get some 105's... car currently makes 20-21lbs of boost
This is a 100% street car and can drive it where ever... Full factory interior, nav, power everything, AC, heat, tint(windsheild also)
$25K
Discussion Starter · #2 ·
Just an idea of how the car actually runs..... Right lane from the pass in the above picture against the blue Mach1.
