1 - 9 of 9 Posts
Where is the fuel filter located on a 2001 V6.
The 1989 Mustang I used to have, it was mounted
outside the fuel tank, and was easily replaced. Is the
2001 fuel filter easily replaced also?
Thanks...
Ok, thanks guys...:)
How often should I replace my filter, and how much does one cost? Thanks.
Correct me if I'm wrong, but I think its every 12,000mi. You can get one at Wal-Mart for about $5. Takes longer to change your oil than to change this thing. Expect gas to come out.
In the thread from the link that was posted above, the guy
took the fuel pump fuse out. On my 1989 Stang I ised to have
it had a pressure release switch in the rear hatch area. Do the
2001 models not have such a switch?:confused:
If the 99+ models are the same as the 94-98 (and for most parts they are)? Then you will have a switch in the trunk in the back on the driver's side.
1 - 9 of 9 Posts
