Would any of you guys have knowledge whether a 2001 Cobra 80mm Mass air sensor fit a 98 gt sohc. I am upgrading to 24lb injectors to the calibration is not my concern it is whether it would. Anyone with knowledge it is greatly appreciated.
Donald
The 01 Cobra MAF is the same as the 99-01 GT's. The injector calibration is done in the computer. I dont know if the 98 MAF is any different then the 99 to 01 GT/Cobra MAF. Anyway the stock Ford MAF's wont make any difference calibrating the injector size. A Pro-M (which usually needs a chip) can be used or you could look into the C&L which uses different sampling tubes to calibrate it to the injector size.
Scott
