1 - 20 of 21 Posts
Here's a video of my car on the dyno. Scroll 3/4 of the way thru to see the pull. I was letting it warm up on the dyno and my friend started filming a little early. I was surprised by the power as you can tell.
Thanks! Me too. I should probably pull a degree or 2 out of the peak torque range but it's so darn much fun I can't bring myself to do it. Lol
What is the difference between the two runs on the screen?
482 lb-ft and 446 hp to the wheels is pretty serious. What is done to the 2.5 and how much boost are you pushing?
Discussion Starter · #5 · (Edited)
Thank you!
I think main difference was 1 degree of timing and letting it cool down for a few hours. Can't remember what the previous run was exactly, but they were all pretty close. Also, previous pulls were 20 psi, this one was almost 22 psi.
Shortblock is stock 2.5L crank, billet rods from boport, CP forged flat top pistons, hellfire rings. Head is stock dual plug, ported, bigger valves, bigger springs for cam, retainers and locks upgraded, esslinger turbo cam, port matched stock intake.
V8 to 2.3 adapter plate for V8 T5 bellhousing, V8 T5 with input I had machined down to fit into 4cyl pilot brg. Aftermarket clutch I had on the shelf.
Turbo is GT35 ebay, 61.5/81.5 comp, 68/62.4 turbine, lowranger96 log turbo manifold, Stinger downpipe, Ebay intercooler kit, ProM 3" maf, stock c1a1 electronics. Tuned with BE and quarterhorse.
That's like about 525 hp and 570 lb-ft at the crank. From 2.5 liters. That's pretty impressive.
What did you do for the flywheel? Aren't the 2.3 and 302 crank hub patterns different?
Also, I once said anyone messing with any Ford turbo 4 other than the Ecoboost is throwing money away. That was just....wrong. I rescind that statement.
Discussion Starter · #7 ·
I bought it from lowranger96, he had a custom spacer made that slides over the crank and presses in the flywheel opening so it is centered, the he had it redrilled for 2.3 pattern. I plan to use the SPEC flywheel they make for this swap, but it's aluminum and I'm not crazy about driving that around town. So it's gonna be sometime down the road when I need a clutch.
Thanks man, this thing has amazed me as well.
What fuel do you run? Is this running pump gas? Head studs?
I am drawn to the under dog. And a turbo 2.5 is an underdog.
Discussion Starter · #9 ·
Lol, yeah I guess it is. These were tractor engines way back when I guess.
E85 from speedway, yes arp head studs, felpro 12 buck graphite gasket has been on it for a year now.
Wow, great build and numbers. I've thought about finding another fox with a 2.3 and doing something similar. Just with pistons and an eBay special turbo build with a V8 T5. Great motivation to get started!
Discussion Starter · #13 ·
I read on turbo forums that he ventilated the engine block.
Yep, one of the chinesium 'billet' rods sheered about 3" up from the big end. Bo said it prob had a bubble or crack in the rod. I'm going with name brand rods and 30 psi when I get back to it. Can't post pics here anymore so if you want to see the whole build go to the turbo forums and find my build thread.
Discussion Starter · #16 ·
Thanks guys! I picked up a set of Crower rods for it from Stinger. After I get paid for some jobs I'm finishing, I'm going to order the pistons from CP. The rods are 5.5" long, where the old ones were 5.3. This will prob help it live
Discussion Starter · #18 ·
Thanks, I can't wait to drive it again. I only have about 4 miles on the cobra brake conversiin before it broke the rod. Very disappointing.
I just spent 25 minutes trying to find your posts on the turbo forums to read about your car. Didn't find them. What's your username over there?
1 - 20 of 21 Posts
