I have a stock bore block and one that needs to go 40-60 over. Also have 3 cylinder heads ported and cut for bigger valves. Blocks have mains but that is all. No cranks, rods or pistons. Have other random stuff for SVO, Turbo Coupe and Xr4ti.
The owner provided dyno sheets from the previous combination. Aftermarket pistons/rods, ported head/intake, cam, and bigger turbo. Made 525rwhp at 20psi. I'm skeptical as I know that dyno shop has inflated numbers before. However it has another turbo now which is more efficient, and makes more boost. When it goes back together I aim to back up the dyno numbers with more accurate data. Personally I think it will take more than 20psi to get there with such low compression. Time will tell.dj9, just curious how much boost you were running to get 500hp?
I'm not sure what the owner will let me do right now. Last we talked it was heading towards 2.5L crank, crower billet rods, and custom pistons...Are you still looking for rods and pistons?
PM SentI do have a new set of Crower rods and 20 over CP pistons. PM me if you are interested.
I'm interested. I assume this needs assembled. What crank does it come with?I have for sale:
cleaned and fresh honed 2.3T block from a 1986 turbo coupe.
stage 4 head/stage 4 cam combo from Boport with heavy springs and big valves.
CP pistons for a 2.3T (paid $250)
billet rods from Boport (paid $250)
new rod and main bearings
main caps have been machined for a strap kit that is also included
let me know if you would be interested in this making room for a new build will sell discounted
