I no crap about suspension so I leave it to you guys. I can install anything they make for this car but what is the best 1st mod to do. I plan on using my car about 1 or 2 days a week at the most but I want ot set it up for the strip ride is no concern it has the stock shocks still hanging on it so it rides pretty rough now it is slightly modded now to get some of that power to the ground, also the tube k-member will be going on this summer sometime
yeah...
...get Sub-frame Connectors...they should be the First mod for anyone going to the Track(ever see a windshield blow-out of a 'stang on launch?)....if its a street car, the Eibach "drag" spring kit is good...Moroso springs if "track" only...loose the frt sway-bar....skinnys up frt....adjustable frt/rear shocks...
anything to lightin' up the frt end..k-member, coil overs, move the batt to trunk, delete the A/C...still, I say the First mod should be tying the frame together either with "weld on" frame connectors or a "roll cage" or both...
Randy Stinchcomb
