Year:1999
Make:Ford
Model:Mustang
Mileage:N/A
Transmission:N/A
Engine:N/A
Trim:N/A
Roller only - $8000
AJE tubular K member
Strange coil-overs up front
Strange brakes and slotted rotors up front
Strange struts
Strange dual caliper brakes and slotted rotors in the back
Built and braced 8.8 rearend
4.30 gears
10 point mild steel cage
Optic Armor front and rear windshields
Racestar wheels with MT Front Runners and 28x10.5 MT slicks
Schoneck 1 piece fiberglass front clip, hood, rockers, dash.
Fiberglass trunk lid
Magnafuel 4303 fuel pump
Magnafuel fuel pressure regulator
-10 an feed line, -8 an return line
ARC switch panel
Trans cooler with -6 an lines to trans tunnel
Optima rep top
Large radiator with overflow
AIS dual nozzle methanol trunk-mount kit
Snow Performance VC-50 controller
Aerospace powerglide shifter
PST 4" aluminum drag shaft included good for 2k hp (fit 351w with powerglide).
Front clip just needs the mounting tree fiberglassed in, hood, rocker panels, and dash still need to be fitted. Roller with previous turbo configuration was a proven small tire car.
Strange struts
4.30 gears
ARC switch panel
Optima rep top
