I suppose I could have put this in both 2 and 4 valve modular tech but its more of a general question.
Im trying to separate the lens of my 99-04 tail lights from the housing and am having trouble. I tried to do the oven method but the red lens is so thin that it starts getting soft and warping before it reaches a glue softening temp. I would try prying it at room temp but it seems to have a lip in most places that has a thin piece of plastic in the way. Id like to get the two apart with as minimal damage as possible. It almost seems like Ford used some kind of glue that is stronger than the plastic it is bonding.
I am also not confident about using my heat gun. Because if even heat didnt work I dont see that a higher concentrated heat will have any success. I see either unfixable warping or melting happening with a heat gun.
