Year:1997
Make:Ford
Model:Mustang
Mileage:100000 M
Transmission:Manual
Engine:4.6 4v
Trim:Cobra
1997 Vortech V1 Supercharged Cobra Project for sale 100000 document miles
Certified #89 - Supercharged from dealer
New T45 5 speed with stage 3 clutch and firewall adjustment
Vortech V1 Supercharged with Autologic chip and Johnny Lighting 3 stage chip
Aluminum 3 core rad - trex pump - all the correct plumbing for SC Cobra with oil cooler
Full MSD ignition
Bad head gasket on driver side (pics show numbers)
Scoped and no damage seen to cylinder walls..might also need value seals
Virgin Motor never apart and still has the sticker (as early Cobra should) with build expert sig
Long tube headers into high flow cats and cat back
Strange rear axels with extended studs
3:73 rear
Front tubular with coil overs
Welded subframes
Battery in trunk kit
Factory 5 rear suspension and drag springs
Auto meter Gauges and shift light
Line locks
Everything works..factory CD player ..power seats..windows..everything
No check engine light or codes
Clean leather and no floor board rot
No body rust
Starts and runs fine..will send vids if interested
Clean carfax - no accidents
Still has the build sign offs on the fenders/so on
Comes with extra 2 1996 Cobra wheels
Bad
1997 White Cobra paint flake- needs a repaint
Motor MUST come out for head gasket
Need trailer to pick it up - has lugs on it but only 3 per wheel
Open to trades
Must be picked up - no delivery
Any trade must be delivered
Shipping possible - but anyone interested should come and see - it will impress
Had to create new account- but long time member saleen90181
Full MSD ignition
3:73 rear
Welded subframes
Line locks
No body rust
Bad
Open to trades
