Hey I have a 97 cobra with a vortech s-trim,36# injectors,bbk tb,and pro M 80mm.The car run good for several months,but just started acting up.It started surging and popping,like it was running rich.I checked the plugs and the #8 plug was wet.All the others looked great.I thought it could be a bad plug wire,do I did that and same thing.I put in a new plug and still no luck.I was thinking it maybe be an injector stuck open.What is the best way to check that.Or is there something else that might be causing it?I have done checked all the hoses and things.thanks for any help.STACEY
