Had both my motor mounts replaced, instead of my car shaking, it now vibrates instead. What would cause it to do this?
Misfire, transmount, suspension bearings, driveshaft balance, rear gear issue
Sent from my SM-G960U using Tapatalk
Check the engine balancer, the rubber seam, movement of the outer ring. Replace it.
Corral Charter Member
I’m betting on the harmonic balancer. The stock 94/95 5.0 balancers were junk. I’ve had a Romac on my Cobra for nearly 13 years now.
