Ok i've been working on the electrical system after numberous problems, and heres one more, the airbag light is flashing 5 times, then 2 more.....then it breaks and does it again, 5 and 2......i assume thats a code 52 for the airbag system? anyone have any ideas? its a 94gt, thanks guys.
michael Reger
I believe thats the code that comes on when you disconnect the battery. Do a search for a guy named stangplus2birds on here. He has a whole page about airbag codes. Its really easy to just short out the airbag harness and reset the system, but you better talk to him first.
Here it is:
Okay, try this:
Cycle the ignition switch to OFF and then to RUN.
Observe air bag indicator prove-out (six ± two seconds) followed by diagnostic trouble code (52-85) flashing completely one time.
Locate the Diagnostic "Trouble Code Clear" Connector located underneath the glove compartment (06010) containing Circuits 631 (T/R) and 57 (BK).
Use a jumper wire to short Circuit 631 (T/R) to Circuit 57 (BK) or to another good ground. *This short must be made after the diagnostic trouble code flashes completely one time, but before the warning light stays on continuously.* (Very important)
Hold short until air bag diagnostic monitor tone sounds (approximately five seconds).
Release short on Circuit 631 (T/R) to Circuit 57 (BK). This short must be released within 25 seconds after the diagnostic monitor tone sounds.
Diagnostic trouble code is now cleared from NVRAM. Next highest priority diagnostic trouble code stored in NVRAM (if one exists) will begin flashing.
Hope this works, let me know if you need more help!
Joe (Fork)
