what exactly would i have to do to get to the gauges itself, i wanna set my speedo right so i wanna pull the needle off and set it right, so how hard is it to pull the needle;) :D
Huh? How did you speedo get so far off that it needs that kind of manual calibration? ;-)
It's easy enough to get at the guage faces, but I would think twice (or more) about trying to adjust the needle. Better to let someone else do it, if you want it to be accurate.
Pull the headlight switch off (there's a release on the side you have to press), then undo the screws above the cluster and remove the bezel. The cluster comes out easily enough (do a search for white face guage installation, you can get pictures of how it comes apart).
I can't think of any reason why you would have to take the instrument cluster apart to adjust the speedo unless it's off a few MPH just sitting at a dead stand still.
