1993 Terminator Turbo ModFox
The car is a 1993 Cobra Conversion. Clean clear title. All the ground effects are real 93 cobra from FORD. Bumpers front and rear as well as side and fender splats. Almost impossible to get your hands on and expensive when you find em. Has the correct 93 steering wheel as well as a working Ford cd player in dash. The entire car has been redone top to bottom. Car has well over 70k in it. If you havent ever built a 4v turbo fox then ask around its is expensive.
The goods:
Motor New 04 Cobra block from ford. MMR 4.75 rotating assembly
2004 DB9 Heads w/SS valves & springs
Upgraded melling billet oil pump and ATi Balancer
Mach 1 intake.
Complete custom built turbo all 2 inch piping v banded.
Custom built headers
3.5 inch down pipe Tial v44 wastegate w/15 spring
Precision 78mm w/ .89ar
Custom made intercooler 3 core 4inch all 3inch piping v banded.
Blow thru slot style unpeggable mass air
105lb injectors running on E-85
Engine Management:
Detail Zone setup with 04 Cobra computer with Custom tune
Prologger Boost Controller w/wideband and data logging
Suspension: Front Upr tubular everything, coilovers, etc etc Cobra brakes
Rear Aerospace brakes, Strange, etc..
Rearend: Built 8.8 33spline, c-clip elim, auburn pro w/3:27.
Tranny: Astro T56 built for 1200hp w/ Spec Twin Disc. Stifflers Crossmember
Custom Driveshaft w/ loop
Exhaust: Custom exhaust 2.5 with dual pipes. Quiet as a mouse
Fuel System: 105lb Injectors, regulator (engine bay), Fore hat w/3 pumps , cobra tank.
Car/Body Mint with Brandnew paint. $8k paint job slick as glass
Pant is HOK flip paint. Only 6 cars in country have this paint currently. Blue. Green flip. This isnt Mystichrome. Looks way better and can be matched. Pictures dont do this paint justice.
Every piece of rubber/moudling/trim is new including qtr windows.
Cobra tail lights, tinted ultra clear headlights and fog also new
Kanean Cowl hood
Interior: MINT Black. Custom door panels. Power door locks and windows that work. Pwr mirrors.
Ac/heat
Factory cd with amp under seat.
Factory 93 cobra steering wheel w/o cruise
Scott Rod Rear Seat delete
Corbeau Seats, 5 point harness and harness bar paint matched.
Custom q-form kick panels for stereo speakers.
Florida 5.0 gauges in graphite
There is plenty that I am missing. This is a solid 9sec street car. Feel free to ask questions. The car has been in storage for a few years. New fluids and cleaned injectors. I have gone over everything and its ready for a new home.
Asking 38k obo. Open to trades for drag cars of equal value or plus cash.
Call or Text- 805-760-0194
The goods:
Mach 1 intake.
Engine Management:
Kanean Cowl hood
Ac/heat
