Small update on the car. Since the last event I've mainly focused on getting the surge tank installed in the car. I also added a access panel so I could remove the in tank fuel pump from the car without dropping the tank. I decided to mount the surge tank right where the spare tire tied down to. This meant I had to move the Accusump back closer to the rear of the car. Which also meant I had to move the breather for the rear diff to the side to make room. Wasn't a big deal moving everything around since I didn't have to change any lines on the Accusump.
I also lucked out that the fuel lines that ran to the tank fit perfect with the surge tank. I didn't have to remake the lines they had the perfect length and fittings to work. I only had to have two lines made for the for the lift pump. I was going to buy the lines but JBA has a really good guy that will custom build lines for you and test them. I gave him the lengths and he made them in about 30min and pressure tested them for me. They don't need to support a lot of pressure sine it's just a lift pump and a overflow but it's good to know they are tested. I also added a second pump to the surge tank that I can use as a back up just in case I have issues with the primary pump.
Now it's back to the dyno to make sure everything is working properly. I was running the Pro-M crank trigger on the car but was running into issues with starting and getting trouble codes due to cam sync. I was also have hot start issues that we just can't seem to overcome at this time. I decided to go back to the distributor and disconnect the crank trigger for now. I'm not giving up on it I plan to try it again since I think it's the best way to go with the car. It's just nice that the car starts right away whether it's cold or hot doesn't matter it just runs and doesn't throw codes.
