92 Gt won?t start unless I ground the OBD1 port top right side I?m taking I got a bad ground can?t find it
how did you elec test, and not find a bad ground?
how did you specifically test?
where did you put the leads?
and NO, ohm test is not good for testing a ground, you do a voltage drop test on an energized circuit.
