This is a 1991 Mineral Grey Mustang with grey interior. The motor has about 1000 miles on it. It is a 8.5:1 motor. The only thing wrong with the car is the overdrive band in tranny is out.Have over $8,000 in motor. Balanced perfectly. Ready for boost. Except for the block the internals could handle 1000+ hp. Here is a list of the parts.
Motor:
It is a 347 stroker 28 oz. balance
TFS forged crank ( VERY NICE )
TFS 5.4 H-beam rods
TFS 8.5:1 pistons
Fluidamper
FRPP high volume oil pump
TFS push rods
TFS stage 2 cam 224/232 .542/.563
TFS track heat aluminum heads O ringed
TFS 1.6 roller rockers
TFS guide plated
TFS tall valve covers
TFS "R" intake
70 mm. BBK throttle body
75 mm. pro m bullit mass air
30# injectors
cold air kit
MDS 6al
MSD tfi coil
3 core radiator
Drive line:
AOD with PI 3500 stall non-lock up
harden one piece shaft
shift kit
tranny cooler
Aluminum drive shaft
3:73 gears
BBK upper and lower control arms
torque boxes are plated
lowering springs
Brand new Welds drag lite and tires
All gauges inside and 2 1/2 cowl hood.
1 5/8 long tube headers
X pipe
flows
2 1/2 chrome pipes
Too much to list. Need to sell fast. $7500
NO TRADES
